Thread: Trouble?
  #35
Old 26th February 2015, 11:42 AM
If you change anything to do with the throttle control, turn the ignition on for 6 seconds before starting. In theory this will check if a basic setting is required (after a battery change or replacement of parts) and do it. There's no obvious sign it's been done, so the manual process with VCDS does give some confirmation that all values are in range.
