If it is the same part as a D2, a new one cost me £102 back in October. Plus another £57 to repair the mullered/corroded plug as the battery acid had eaten the terminals AND the plastic plug! The wiring on the D2 is ridiculously short so I bought 3 repair wires and a new plug and had my local indy make the joins as it really needed 2 sets of hands.
Mine did the 3 chirp on ignition on twice before i replaced it and it was already way too late....
I don't think it logged a fault code, but if it's going off it should record what the trigger was, unless the unit is shorting and setting itself off?
