Old 10th February 2009, 03:31 PM
Originally Posted by Simon Wallwork View Post
Ian
The car's a Nov 99 facelift S8. It's got the colour screen, moving map nav kit.
S
Edit to add: It's called 'Navigation plus'. Has an audio output + the directions come up on the instrument cluster where mpg etc is normally displayed. Actually it looks quite good the way it is. I'll need to read those instructions!
Its likely the older RNS-C unit then, they're quite capable but not as fast as the later units...
The discs were discontinued in 2007, so you wont get any later ones, and I dont know of any firmware updates.
It is possible to upgrade he RNS-C to RNS-D, but it also requires a TMC module installing so you get the turn by turn instructions on the dashboard.
For casual use, the RNS-C is fine. Roads dont actually change that often, so a 2007 map disc is quite useful. I can't see the small increase in performance making the relitively costly upgrade to the RNS-D worthwhile...
