Old 2nd March 2015, 12:15 PM
Zip's Avatar
Zip Zip is offline
You can see them clearly on the photos of my refurbished calipers: http://forum.a8parts.co.uk/attachmen...7&d=1379181239
...and you can clearly see where the corrosion has been ground away under the stainless plates, where the new finish is "pitted". Those plates need to be absolutely flush and square in the calliper, or the pads will not retract properly. Indeed, if too much is ground off, the pads will rattle around in there once the plates have been screwed back in. I'm not sure I have photos of mine, but I'll have a look. They were pretty bad pre-refurb.
Z
