Old 2nd March 2015, 11:10 PM
ian_s ian_s is offline
OK, thanks, not my situation.
If I clear the 01119 error it comes back "sooner or later" (usually sooner) but not after every journey.
And I have no other codes and no warning lights.
Do you recall what the TCU error was?
It seems to be a pain, i've just been researching 01119. I can't see how the speed senders can be connected to this fault but you never know.
The fault was 17090 Trans range sender f125 implausible signal. This ties in perfectly with 01119 as the abs unit can't understand the gear selection position. When I replaced it I thought that the state of the connector was more to blame than the f125 itself. Worth a loom at the connector first as the f125 is an awful job even on a ramp.
