View Single Post
Old 4th March 2015, 04:41 PM
Originally Posted by tonyt102 View Post
Finally all sorted. Looks like the box had been leaking for so long that the level was too low. Had a replacement prop end seal fitted along with a full flush and service and it's fine now.
There are four separate oil chambers on these boxes. The leak from the rear output shaft seal you talk about is a common issue.
