Old 5th March 2015, 12:25 PM
Burnzybubbles's Avatar
Yes, I vaguely remember on my old PF S8 having some work done (years ago) that required draining the coolant.
All seemed well until a few days later I was driving "vigorously" off the M25 northbound onto the M40 eastbound, which many (most) will know is a "grip-testing" 2-lane slip road that turns about 270 degrees left in one smooth curve.
I know this corner well, the A8 I think will do it at about 70-80mph lol! Funny when you join the m40 and everyone is looking at you as you fly past on the slip road.
To the original poster the coolant drop is fine and that's more than likely why he overfilled it to account for air left in the system, bit like an oil change, I'll overfill slightly to allow for the oil filter, best thing to do regarding air in the system is roll the windows down put the heating on full heat and take it for a spin getting it upto temp and using all the Rev range as this will open the heater circuit and using the Rev range will be running the pump at full tilt helping push out any air that may be hiding, top up to max if it does drop and then just check it as usual.
My misses zafira had an air pocket for 6 months ish after I did a belt and pump change, she hardly uses the heater though and I didn't get chance to take it out properly, went to check her oil one day and noticed a drop in coolant, filled it up and been fine ever since, reaches temp better too now, I was blaming a facet stat from ECP to begin with.
