Originally Posted by 3.7 slp
Sorry there was a lot in that post...  it was that the level dropped slightly after the rad change , it was overfilled by my Indy that did the job, so just wanted to check if that would be normal. Its come down to the Max mark now give or take …and keeping an eye on it to make sure all is ok, was just checking where most find their coolant level sits at which checked cold.And if the drop would seem normal
In my experience everything you have described is normal.
