Old 6th March 2015, 09:27 AM
mattsimis mattsimis is offline
Is the CD Player enabled within the CAN Gateway?
Select Module >
19-CAN Gateway>
Installation List>
Scroll down and make sure 1E is ticked.
I think it will be ticked from your latest scan, but worth a check.
Yep it is.
I had a theory that perhaps the CD Changer needs to be media device 1 to work for the FW update, mine is 2 (MD Player is device 1). Frustratingly I cant get my Radio removal keys to work in it so taking it out to disconnect one unit is proving hard.
Also I found the LVDS box under the passenger footwell in a plastic box. It has 3 multipin cables connected to it. One is LCD control, one is HU and one is marked Nav. Removing either of the first 2 disabled the MMI screen (which is now popping up when the car is alarmed and shut annoyingly).
Dug all the way back through the glove box to the MMI control unit.. which seems likely Ill need to change, photos attached.
ID:	10290   Click image for larger version
ID:	10291   Click image for larger version
ID:	10292   Click image for larger version
ID:	10293   Click image for larger version
