  #149
Old 6th March 2015, 05:01 PM
Just a minor update on this still-unresolved issue.
Errant behaviour still happens every now and then, so I've now followed the lead of some others and order a replacement throttle pedal position sensor (potentiometer) from our sponsors.
The car is due in for a check up on a lift later this week; loud rattling when cold from under the car (stationary or moving) so I suspect that the iffy catalyst is on the way out and that the SAI pump is adding to the symptoms when cold. Might get the garage to fit the replacement potentiometer at the same time if it has arrived.
If you post up your short / long term fuel trims at idle i can advise if they are healthy, group 033 ad 034 screen grab.
Make sure you have some miles on the car since the last time you cleared codes in engine module group as is reset when this happens.
