  #152
Old 6th March 2015, 08:01 PM
You're on a fly by wire throttle, so the cruise control sends its own signals to the throttle/ECU.
Can't remember.. did you do the new throttle sensor like Jim had fitted recently? I'm sure there's a VCDS measuring block for pedal position, might be worth just playing with that when cold to see if it gives the figures you expect.
