  #156
Old 7th March 2015, 11:11 AM
That description of operation describes exactley how your car can show these problems, if one pot is slighty iffy then you would get the reduced power that he mentions that clears in release of the pedal, is it possible to log the pots in VCDS and go for drive, then once you have a fault scenario you can timestamp I vcds so the log shows when the fault was so you may find it easier lookng through the log later.
