  #161
Old 7th March 2015, 05:15 PM
is it possible to log the pots in VCDS and go for drive, then once you have a fault scenario you can timestamp I vcds so the log shows when the fault was so you may find it easier lookng through the log later.
I'm beginning to think I'll have to do that, but it will probably take whole a load of test runs to get anything useful.
I added more info earlier after taking the knee panel off, but it's disappeared.
In summary I can see the unit and its moving properly, no slack no fouling, but is a pig to get at with a big air duct in the way.
I can only see one retaining screw for the duct and taking that out makes no difference, I think all the carpets and trim panels will have to come out first and reveal more fixings.
When it's a bit more springlike I'll probably do that to clean all the carpets etc. after winter and have another look.
If I still can't get the duct out I'll probably hand it over to my garage. I'd take all the trim out anyway before doing that.
But a test run logging the pedal position while recreating the problem would be very instructive. I just have a suspicion that it will show the position signals are correct..... So the sooner I can achieve that the better.
