You will need to retrieve the SKC security code from the original ECU or VDO in order to pair the donor for IMMO reasons. Some specialists have that equipment and failing that its a Gekko dial up job with the dealer. Sure you mechanic knows that but i would also enquire how he arrived at that conclusion - presumably he has removed the rear lid and seen the circuit board is black and discoloured for instance but let him answer that part..
