Old 28th March 2015, 03:47 PM
Set the clock to 2.50am and then lock and leave the car for an hour or 2 - should have sorted itself out by then if you keep disturbing it then it won't sync and the car needs to be shut down
When it's set the date will be correct but the time will be on mainland Europe so you then try setting the time manually and can correct the hour, but no other settings.
Be quick about it and come tomorrow morning it will have reset for daylight saving time automatically
The little mast symbol will always display assuming there's no failed time sync in normal use - mine works in the factory position even though it's always garaged when it's checking the time
