Old 28th March 2015, 04:26 PM
Went to TPS this morning and bought one of each to see which fitted, and can confirm that the fuse holder takes 4.8mm terminals. From my first picture you can see that the 4.8mm is a twin crocodile terminal. The terminal is secured in the fuse holder by the purple lock, which is easily moved by a flat screwdriver.
For reference here are all the part numbers of repair wire and bare terminals for crimping that fit.
Repair Wire:
000979023 4.8mm terminal with 0.5mm wire
000979135 4.8mm terminal with 1.0mm wire
000979227 4.8mm terminal with 2.5mm wire
000979306 4.8mm terminal with 4.0mm wire
Bare terminals
N90732603 4.8mm terminal for 1.0mm wire
N90732703 4.8mm terminal for 2.5mm wire
N90696603 4.8mm terminal for 4.0mm wire
N90422102 4.8mm terminal for 6.0mm wire
ID:	10402   Click image for larger version
ID:	10403   Click image for larger version
Matt
