5 - 6 hours is about right not inc alignment.
Inner rack is worn ? Not the most specific diagnosis. The rack and pinion are made of pretty hard core steel. I hope he is not confusing it with inner tie rod play which is weaker given the plastic cup inside the balljoint which wears and you get a knock.
Although to change the inner tie rod, its a rack out job.
