Old 7th April 2015, 05:29 AM
Welcome to the forum
Looks like a stored fault from the transmission ECU from over 2 months ago - clear the fault and see if it returns. I would certainly check the gearbox oil level to see if you've lost any fluid, and then finally possibly change the oil and perform a gearbox adaptation to go with the change, which your dealer would need to do
