View Single Post
Old 22nd January 2010, 06:06 PM
tonyt102's Avatar
tonyt102 tonyt102 is offline
Well, had all of the vacuum hoses replaced to no avail.
I have plugged VAG COM in tonight and it brought up no fault codes. I'm quite new to VAG COM so correct me if I'm wrong. I went to the measuring block section with the engine running to get some values for misfiring cylnders and ignition timing. There was no misfires logged although the timing showed between 12-14 degrees BTDC @ 800rpm - is this right as I can find out what it should be? Shouldn't it be 0 degrees or near?
