It's 'relatively' easy - it is much easier if you remove the fittings for the boot side to give full access and that involves removing the trim across the bottom of the boot opening too. None of it is difficult but requires a bit of care. There's only a few nuts holding the light in place but there's a couple of plastic barbs that need careful alignment or you will break them
Did my OSR recently as it was cracked from when I bought the car
Will post a pic when I get home of how much needs to come out (it's pretty much the same as accessing the battery in order to get it out!)
