Old 26th April 2015, 03:33 PM
Chaps on Audiworld have done it by dropping the mount slightly instead of taking the whole strut out which is the way I think I will go at it once I order the bits.
Yes, drop the strut - The airline connector can be cleaned and unscrewed to remove that - then just take the three bolts out in the engine compartment and it should come down as far as I recall. Also the day before, give it all a good jet out at the jet wash or with pressure washer. Nothing worse than avalanches of silt dropping down every time you bang something.
