Old 26th April 2015, 07:39 PM
For the drivers' side on my 3.0TDi, I just removed the airbox and removed the two torx bolts holding the bottom of the lamp and the two smaller ones on top to enable the lamp to slide forward a bit. A mirror on a stick tool helps see the bulb is aligned when refitting.
On the passengers' side, you need to remove the wheel arch liner and maybe the PAS reservoir, but I didn't bother.
