Old 27th April 2015, 01:33 PM
Originally Posted by centurion View Post
I've recently replaced front track/tie rod ends [only] on mine. Garage had checked all other elements and have not found anything 'wrong' with them but I still get the nasty squeak when the car is cold going over speed bumps in the morning... once it warms up it's all fine but it doesn't feel right on the steering either... it's been to the garage several times and going back in tomorrow morning and if they cannot find anything I was planning to replace all other joints/part on the front suspension. hence i'd appreciate if anyone could list parts and part # associated so that I could order those and close this off once and for all?
Cheerio
The squeak you hear is from antirollbar bushes mate, problem is that on D3 you can't replace them on their own, there is no even part number for it, all you can do is replace whole antirollbar but it's pointless coz the only thing wrong there is that bloody squeak, and not even always when called.
Also very similar squeak been reported with D3s and it was the actual shock absorber which again needs to replace as one piece.
As you say, there is nothing wrong with the suspension in regards to handling or knocks, it's just bloody squeak.
You live with it or splash few hundreds to replace bar which is fine more likely.
For the arms Mister Auto is great, just type in your reg, go to suspension arms or something like that and just filter parts by manufacturer Lemforder and you done, all there, there won't be two different but same parts, add to basket, pay, wait for the parcel.
