Old 6th May 2015, 10:06 AM
centurion centurion is offline
something that helped me in the past was Archoil AR6400-D... worth giving a go to clean up the system [as much as it could] and you could follow up with higher octane fuel afterwards to check if it is any better.
...at the same keep on monitoring in VCDS for any obvious issues/errors.
ps. i recently had MAF problems and it never came up in VCDS.
