Old 21st May 2015, 09:41 AM
Default Parking sensor problem
Now, I've had parking sensors go before, and replaced the control box, but this is a bit odd.
When starting from cold, the front sensors beep continually (each beep lasting2 or 3 seconds or more) with short gaps between the longer beeps. Once the car is fully warmed up, they work normally.
There are no VCDS fault codes and the green light on the switch doesn't flash (IIRC, it does when one of the sensors is faulty).
Any ideas?
