Old 23rd May 2015, 02:03 AM
mattsimis mattsimis is offline
Default Stuck mid way through job.. can't get steering column off
Got what should be the hards bits done, airbag out, steering wheel removed.. But can't find any fitting for the 2 deeply recessed screws either side of the lower column.. See photo. I can't even see the type of fitting, in so deep.
Need the column off to replace a broken cruise control stalk!
