Old 25th May 2015, 07:35 AM
Johnmed's Avatar
Johnmed Johnmed is offline
Seems like coolant thermostat to me. Have you ruled out the temperature sender?
On the A2 (3 cyl) TDi these were common failures/easy enough to replace. I replaced mine as a preventative measure, along with the coolant thermostat (that had failed).
I'm guessing on the 8 things aren't quite as simple
2007 Mini Cooper S R56
