Old 26th May 2015, 07:30 PM
oldnick oldnick is offline
You can get away with a 2mm tread depth variation across each axle and the average of the front and rear measurements can vary by 2mm as well. Only time that doesn't apply is with an electronically controlled diff when they reckon the rears should be as close as possible to the same tread
It's in elsawin as general guidance
sounds like advanced maths to me ,lol
to pass an MOT in france you must have the same brand and type of tyre on an axle with less than 5mm of tread depth difference down the centre ; so not as tight as a quattro!
could be a case for a front to back change on one side to keep to the 2mm limits as it works on averages , wouldn't have thought of that
