Originally Posted by Adrian E
LiFePo should be OK for starter duties - LiPo doesn't like being deep discharged and is a bit like a live grenade if mishandled! The ferrite versions are lower voltage and generally don't mind a bit of abuse. Not sure it's worth the aggro unless your car is on a serious diet though?
My 911 is lighter than a standard G50/1987 car with f/g bumpers, sunroof delete, recaro furious, rear seat delete, plastic rear light clusters, ally clutch housing, but not what I call serious. Maybe 75kg saved, which isn't too bad in a car that weighs 1200kg standard.
Standard battery is 18kg so if I can loose another 12-15kg and add some useful functionality like BMS, it's worth it to me as my lockup has no power.
