  #36
Old 8th June 2015, 01:33 PM
oldnick oldnick is offline
There are many different gearbox codes, but only a handful of different ZF gearbox designs in use.
The main difference with all the Audi codes is the final drive ratio for the output on the front axle that is built in. Ideally it wants to match like for like, but worst case you need to change the rear final drive too (in quattros) or its gonna get messy...
I have seen D2's 'repaired' with the wrong gearbox before now, but probably not recommended.
On front wheel drive cars you have only a gearbox code, which includes the final drive ratio for the front wheels in the box.
On quattros you have 2 codes, one for the box, and one for the rear diff.
Get the right gearbox code and all will be well...
so is it engine , diff, box or engine ,box ,diff ?
