The actual picture is an analogue connection between the TV Tuner and the MMI control head, I don't think a signal issue would cause that. A signal issue would just cause breakup of the image or no reception at all. DVB-T is either on or off, the picture should remain the same. You could check the connections on the Tuner in the boot, it wont the be fibre or power connections but the single connection on its own that is the video out.
