Originally Posted by mattylondon
I'll give it a go at the weekend. Del, have you logged your data in to Excel to analyse and compare runs?
I tried Matt but I'm a thicko when it comes to excel and charts. I tried to import the data from the log but it puts empty rows between data and I can't think of a way to clean it up without doing it manually.
So I gave up
What I would like to do is log the run alongside things like maf readings and fuel rail pressure, ignition advance, lambda values etc but I can't do it as VCDS has no label files for the s8 engine
