To be honest because ive set the parameters on vcds its only ever maxed out in lift mode .. it acctually only sits 20mm higher in comfort that before. So i guess you would argue it will add more strain to things like bushes and joints but only briefly while in lift .. you use it when needed not all the time of course ..
