Old 5th July 2015, 08:37 PM
S mode came later than facelift - I think late 2001 but not sure from which VIN without looking it up in ETKA to see if there's a rangE given for the s mode gear selector
As said,can be retrofitted easily
HP is right about the throttle body reset - without vcds you can do basic settings for throttle position by switching the ignition on for 5 seconds without starting the car. If the ECU decides it needs to perform a basic setting it will do it at that time
