Old 21st July 2015, 01:01 PM
Not sure if cigarette lighter is live with ignition off on D2 but A6 I often charge through the cigarette lighter in the boot as I can put the charger and the end of extension cord in the boot an lock it while charging. Even if it is not live with ignition off you can still use it just turn the ignition on, you only need it for long enough to use central locking to open the boot then you can connect to the battery. If you use connections in the footwell you can use any of big red wires marked '30' for positive
