I would suspect it may be sensitive to wattage. I'd probably try borrowing a different bulb from the cluster somewhere into the airbag slot and see what happens.
The prefacelift clusters, in terms of the airbag light should be re really very interchangeable, and the facelift cluster just wouldn't fit, so I doubt any sort of cluster swap is as fault.
The error message does seem really very specific, and in my experience I would definitely be concentrating hard in that area alone.
The only thing you don't mention, but I assume you did, is to check the soft coding on the replacement module to ensure its coded the same way as the original one you took out ?
Its seems an incorrect code is unlikely as you'd get errors about airbags being present not expected or vice versa potentially, but worth mentioning.
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
