View Single Post
Old 24th July 2015, 10:54 PM
Pretty sure there is only 1 one power source for all the factory ICE in the car, fed from the boot right hand side.
If the RNS-D is working, then most likely your TV tuner has failed for some reason. Rare, but possible.
The presence of the tuner on Canbus will cause the RNS-D to allow you to select it, so unless the cable for the tuner running from the front of the car to the back has got damaged, then providing there is power to the tuner (which its hard to believe there isn't) then faulty tuner seems most likely.
The RNS-D tuners are all analogue, and should be relatively cheap to buy now as there is little demand. Swapping it out may be your next best option if you need it to work.
