Old 27th July 2015, 04:04 PM
Driver's side I haven't done yet. Couldn't remove the trim on the side of the transmission tunnel. Does the panel under the steering wheel need to be removed first?
Usually, unless like mine someone has been in before and ripped things out brutally.
The knee panel is attached to a small plastic bracket on the transmission side panel so has to come off first.
IIRC there are about 5 fixings, two behind the pop-off trim strip below the steering wheel, top right, bottom right and bottom left (onto the bracket)
