Old 31st July 2015, 08:11 PM
I have adapted the wiki destructions from Q7 to A8, but does anyone know what the Camera Height coding below means?
Mine is set to 04 +50mm on my second hand A8 unit.?
Audi A8 (4E) Rear Camera
Coding
▪ ?0x0xxx: Manufacturer
▪ 1 = Audi
▪ x0?0xxx: Trailer & Parking System
▪ +1 = Trailer Hitch installed
▪ +2 = Optical Parking System installed
▪ x0x0?xx: Camera Height
▪ 0 = Camera Height 1
▪ 1 = Camera Height 2
▪ 2 = Camera Height 3
▪ 3 = Camera Height 4
▪ 4 = Camera Height 5
▪ 5 = Camera Height 6
▪ 6 = Camera Height 7
▪ 7 = Camera Height 8
▪ x0x0x??: Model
▪ 01 = Audi Q7 (4L)
▪ 02 = Audi A8 (4E) Short Wheel Base
▪ 03 = Audi A8 (4E) Long Wheel Base
▪ 04 = Audi A6 (4F) Sedan / Rest of World (RoW)
▪ 05 = Audi A6 (4F) Wagon/Avant
▪ 06 = Audi A4 (8K) Sedan
▪ 08 = Audi A5 (8T) Coupé
▪ 12 = Audi R8 (42)
▪ 14 = Audi A6 (4F) Sedan / China (CHN)
Camera Calibration
After performing service work, the calibration has to be performed too.
e.g.:
▪ Removing and Installing Rear View Camera (R189)
▪ Replacing Rear View Camera System Control Module (J772)
▪ after repair work performed on rear lid following an accident
▪ after a vehicle alignment
▪ after performing a repair at front or rear axle
Prerequisites:
▪ Calibration Device (VAS 6350) and Distance Laser (VAS 6350/2) positioned as described in the factory repair manual.
▪ Vehicle must be standing on a firm and even surface.
▪ Tape measure
▪ Do not move the vehicle and do not operate the vehicle doors while performing the calibration.
▪ Rear Lid must be closed.
▪ Front Wheels straight, Steering Angle Sensor (G85) close to 0.0 ° in Measuring blocks 005.
▪ Ignition must be ON, Engine must NOT be running, you may connect a charger to keep the system voltage up.
▪ Back-Up Camera active and the MMI shows Back-Up Camera Video Signal.
▪ Make sure you do NOT have light reflections on the Calibration Device (VAS 6350).
▪ On vehicle vehicle’s suspension Level Control, set the Height to automatic.
[Select]
[6C - Back-Up Camera]
[Security Access - 16]
Enter 22351, to enable the adaptation.
[Adaptation - 10]
Channel 005
[Read]
500 mm is the basis value of channel 005. Measure the heights between the Calibration Device (VAS 6350) and the ground surface
(e.g. 80 mm for OE, 4mm for cardboard), add 500 mm to it and enter the final value as new value (e.g. 500 + 4 = 504 mm).
[Test]
[Save]
Channel 004
[Read]
20000 mm is the basis value of channel 004, 2944mm (wheelbase for Audi A8 SWB (4E) or 3074 mm (wheelbase for Audi A8L (4E)).
Measure the Distance between the Calibration Device (VAS 6350) and the rear axle (e.g. 1500 mm), and subtract it from 20000 mm minus 3074 mm
enter the final value as new value (e.g. 20000 - 3074 - 1500 = 15426 mm).
[Test]
[Save]
Channel 001
[Read]
To save your above adaptation save a new value of 1 to channel 001.
[Test]
[Save]
The screen will go black now and it will now take several minutes to calibrate - read on how to see progress...
[Done, Go Back]
Now watch the calibration status.
[Meas. Blocks - 08]
Block 130
[Go!]
Block 130 Field 3 (Calibration Status)
See popup for what each code means.
Specification: 0x0000 (Calibration Successful)
[Done, Go Back]
[Close Controller, Go Back - 06]
