Old 5th August 2015, 09:18 PM
Well, thats not good news. The 'stat requires removal of quite a lot and its generally considered a good idea to replace timing belt and pulleys, water pump at the same time.... which can be a big expense. I just paid that bill today ..... - Dont ask.
However, I am not sure how a 'stat failure/defect can cause the behavior you have outlined. Failure is normally a on/off situation whereby failure leads to it not opening and overheating of the block. I cannot conceive of a failure mode whereby it operates at a different temperature.
BTW, Why was the CTS replaced earlier?
