Old 18th August 2015, 07:30 PM
Same here.
Always rises to 90 then stays there .... apart from when I had a coolant temp sensor fault (when the needle stuck at zero), and the time I lost all of my coolant while right-footing it down the motorway (causing the gauge to move up slightly).
I wonder if your thermostat is sticking a little, or opening late. It's possible the Radweld is responsible if that's the case, especially if it started happening just after that.
Might be worth checking the temp with VCDS (assuming VCDS can read the CTS temperature - never tried it myself) just to confirm whether the ECU is seeing the same temperature the gauge is reporting ... though I suspect it will be.
