Faulty n/s rear caliper ....broken wiring
After recently getting a warning on the dash - indicating failed park brake, I hooked up my Diagnostics which brought up a fault, which I was unable to clear.
It pointed to the n/s caliper suggesting an open circuit.....
I remember the previous owner having only just replaced the n/s rear caliper and ecu last September (2 months before I bought the car).
"Happy days" I thought. It's only 11 months ago and will therefore be covered by the Audi 2 yr parts warranty!
Not so.....it transpired the open circuit was a broken wire on the connecting plug, to the caliper, but on the CAR side of the wiring.
Bugger!!!!
Interestingly enough though, when I got to the caliper connector, it wasn't housed in the forked mounting bracket and the cable connector rubber cover/sheath was pealed back from its recessed 'home' position?
So, it's a DIY job for me. It's the thicker cable that goes to #4 connection on the plug, but, it's very close to the connector, leaving little room to work.
So, before I ramble on any more, does anyone know of a special tool that removes electrical pins, to enable me to carry out a nice wiring repair?
Any help advice appreciated.
Previous cars
A8 D4 4.2tdi lwb (2011)
T5 Caravelle exec 2.5 (2006)
A8 D3 4.2 quattro (2003)
A6 4.2 quattro avant (1999)
A6 2.8 quattro (1998)
Audi Coupe 2.6E (1993)
Carlton 3.0 GSI
