Originally Posted by tc4332
Hi Burnzey, If I manage to locate an oem aerial that would be the ideal answer.
The OEM route is very easy on these cars.
All the D3 aerials come off the rear screen. Same screen whether TV/DAB/FM etc.
There is an aerial module under the trim at the top of the rear window. There are different modules supporting different aerial configs.
Just swap the aerial module for one that also has a DAB output, then run a Fakra cable from that down the D pillar to the boot area....
Not guaranteeing this is a direct fit for you (check first) but heres an example one:
http://www.ebay.co.uk/itm/Audi-A8-D3...item2c94eb5b27
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
