Thread: Headlight Level
Old 24th August 2015, 07:40 AM
Ah so you have an issue with the adaptive suspension, that will create problems with headlight levelling as the info comes from the suspension height sensors.
Have you any faults logged for the level sensors or the level system in general like leaks, over temp etc.
If you do have a leak you run the risk of your compressor dieing trying to make up the loss.
