Old 13th September 2015, 07:21 AM
I think car being German the limit is set in km/h at 250 not at 155mph but it's pretty much the same speed anyway. Speedo reading is is way out, you will be seeing about 280 on the clock by the time 250km/h limiter kicks in. Compare the speed on the clocks to GPS and you will see the difference or even better to the speed in VCDS as that is the speed that limiter will use and it can vary from GPS speed depending on tyre size and wear.
