Go Back   A8 Parts Forum > A8 D4 > D4 - Sat Nav, ICE, Audio & TV
D4 - Sat Nav, ICE, Audio & TV All in car entertainment discussions including MMI 3G Plus
Old 10th March 2025, 10:09 PM
Slabber Slabber is offline
Default Antenna for GPS Navigation Open Circuit Fault
My 2010 4.2 TDI has a 00862 - Antenna for GPS Navigation (R50/R52) 011 - Open Circuit fault. An internet search indicates that this fault is typically associated with the navigation location being completely off by many miles, and the fix is to replace the sharkfin antenna. However navigation location is spot on in my car.
I want to fix this as I think/hope it's the cause of an ACC and Audi braking guard: Unavailable issue that I've got which coincides with this code showing up and from another internet search seems to be related.
Before I replace the sharkfin (4H0 035 503 A, £186 new) does anyone know if this fault code and an accurate navigation location are compatible? Is there anything else I can easily check before replacing the sharkfin? Thanks in advance!
Old 11th March 2025, 09:39 AM
pete-p's Avatar
pete-p pete-p is offline
It looks like the antenna can cause the ACC and braking guard to be unavailable. Some sort of fail safe if a module goes down.
Maybe it's still able to receive enough satellites to give an accurate position?
Cars...
Old 11th March 2025, 07:37 PM
Thanks for those thoughts Pete! I'm very close now to ordering anew antenna: I have the rear headlining panel removed and have access to underneath the sharkfin. I've fiddled with the connections in the hope that it might miraculously fix it but no joy. I think I'll have to assume that the connections at the other end (at the head unit?) are sound unless it's an easy check and someone can point me in the right direction.
For anyone else needing to do this I'm following this video.
Old 17th March 2025, 09:38 PM
Just to confirm, issue was faulty sharkfin antenna - connecting a new unit allowed the 00862 - Antenna for GPS Navigation (R50/R52) 011 fault to be cleared and adaptive cruise control is now working again.
Old 14th May 2025, 11:14 AM
Horrgakx Horrgakx is offline
That's good news. I have an intermittent ACC and Braking Guard unavailable message too (D4) but there's no mention of GPS errors.
A8L W12 (D4 2015)
