Dear fellow A8 M8s
I have a problem with the coding on my 08 HVAC - there is no coding helper in VCDS is it just mine? I have tried a few codes I found online but this caused all kinds of problems. Please can anyone with the following or similar spec dig out a VCDS log and copy and paste then post their [08] HVAC coding.... A8L 3.0TDI 2006 Right hand drive Quad-zone climate Front and rear heated seats Auxiliary heater No vented seats No sunroof No heated windscreen Thanks you! Last edited by snapdragon; 23rd December 2014 at 05:05 PM. |
Here is mine.
Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 HW: 4E0 820 043 A Component: KLIMAAUTOMAT 015 0240 Revision: 00000018 Serial number: 00000000023996 Coding: 1069057 Shop #: WSC 02311 785 00200 VCID: DABB0B6F150DF5CE353-808F
Is this of any help?
http://www.audi-resource.com/ecu08.php This is mine Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 G Component: KLIMAAUTOMAT 017 0450 Revision: 00000032 Serial number: 00000000106345 Coding: 0057465 Shop #: WSC 02313 785 00200 VCID: 1C373B69DFDF87F8DC3 A8L 3.0TDI 2006 / Petrol 5.2 Right hand drive Quad-zone climate Front and rear heated seats / Front heated only Auxiliary heater / No Aux heater No vented seats No sunroof / Have sunroof No heated windscreen HAVE YOU SEEN THIS SITE http://www.netech.dk/index.php/ecuuk
Del ![]() Last edited by Delboy; 24th December 2014 at 04:46 AM. |
It may be worth you looking through your debug logs to see what you have changed in the past.
goto c:\Ross-Tech\VCDS\Debug\CodingLog.txt (coding changes history) or c:\Ross-Tech\VCDS\Debug\AdpLog.txt (adaptations changes history) Good luck P.s if you have time I recommend you and everyone else to do the following it will help us all in the long term I'm sure http://wiki.ross-tech.com/wiki/index..._can_I_help.3F
Del ![]() Last edited by Delboy; 24th December 2014 at 06:44 AM. |
A big thank you guys - going out now to have a fiddle.
EDIT** Great stuff- I set a new code of :- code 1 1+2+8+16+64 = 155 code 2 2048+16384+32768 = 51200 code 3 65536 TOTAL CODE = 0116891 I hope I did that right, I have all the correct options afterwards anyway. I also set these adaptations (although some already set and others not implemented) 06 0=intelligent aux heat/vent 07 1=shut off time aux when ign off 08 1= voice recognition quiet mode 16 1=activate aux heater if required for residual heat function 18 0=shut off when energy manager says so 19 0=use aux heater when required by heater demand 20 1=rear heated seats not switched off after 10 mins 21 1= add another line to MMI I hope to add the valve and electric pump to the Webasto heater one day. Rear heated seats still don't work. Fuses OK, switches show as on, MMI shows them as present and on. I have disabled the 10 unoccupied minute timeout. Seats remain cold. I looked in measuring blocks of 08 HVAC and can see the temperatures of the seats as ~8˚c and it also shows all 4 seats as unoccupied even when I sit on them. Maybe that is the problem? Last edited by snapdragon; 23rd April 2020 at 08:19 AM. |
Hi. i did activated the additional heating and ventilation but not the engine worm... how to do that ? thanks
commander sildenafil 100 pfizer 100mg www.viagrasansordonnancefr.com |
Snap, did you get any where with AUX pump fitting?
I fitted the water pump to the auxiliary heater on my car but it's a 4.2 tdi , if you need to ask any questions about it will try to help
