Old 27th September 2015, 06:00 PM
Default Suspension height recalibration needed?
I've noticed that my rear right wheel has recently looked more into the wheel arch than the left. I park on a uneven surface so it may just be a visual thing. But today I decided to plug VCDS in and take a look at the measuring blocks and log a little 6 minute drive. I logged block 5, absolute vehicle height, which gives a reading around 100mm for each side.
After the 6 minute journey the average height for each side was
Front Left +103.5mm +97.0mm Front Right
Rear Left +115.4mm +101.9mm Rear Right
With this result I now don't know if the rear left is too high because the other 3 sides are around +100mm, or the rear right is too low?
I expect that the left will be a little higher than the right side to compensate for the camber of the road and me in the drivers seat.
Does anybody know any base settings for each side? Should it be around 100mm? Should the rears be a little higher? And would a suspension recalibration be needed?
Below is the logged line graph of the journey. Quite interesting as you can see the majority of the journey was left turns.
Matt
Old 27th September 2015, 08:10 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Can't answer your question Matt, but a suspension height calibration is quite simple to do if you haven't already. Tape measure, VCDS and a spare 30 mins or so is all it took me.
Can't see how a recalibration wouldn't help in the above situation.
2007 Mini Cooper S R56
Old 28th September 2015, 08:44 AM
Thanks John,
I'll get the calibration done. There's a shopping centre car park with a lovely latex top screed near me, it will be near level for the calibration job.
Did you do it with the car empty or somebody sitting in the driving seat?
Matt
Old 28th September 2015, 08:47 AM
47p2's Avatar
47p2 47p2 is offline
Worth checking the rear left sensor isn't seized or faulty before proceeding to alter the settings
Nite Blue 3.0L SE Quattro
Old 28th September 2015, 08:49 AM
Johnmed's Avatar
When I did mine I was assisted by my 4 yr old son, and he sat up front and I was in the driver's seat. In and out to measure the distance from the centre of the wheel to the arch.
We were on a very quiet road, but we probably got a few odd looks.
Old 28th September 2015, 09:08 AM
Will check that, thanks
Matt
Old 28th September 2015, 09:12 AM
So may I when I turn up with a theodolite and taking up 4 parking bays
Matt
Old 28th September 2015, 09:34 AM
mannyo mannyo is offline
The level is meant to be calibrated with nobody in the car at all, all done from outside with the VCDS cable through the window.
Manny
Past
Old 28th September 2015, 09:35 AM
Johnmed's Avatar
I think I will redo mine when I get a quiet day, just to be sure all is well, as I was a little preoccupied when I did mine.
Old 28th September 2015, 09:39 AM
Thanks Manny
Matt
