Old 20th January 2016, 01:20 PM
ulfilias ulfilias is offline
Default First Vag run on new car!
Just got a Vag run on the new beast. Any comments welcome. Particularly in regards to reseting the leveling stuff as getting the headlights level and not very short would be great at this time of year!
Wednesday,20,January,2016,13:18:27:05031
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 15.7.1.0
Data version: 20150904
www.Ross-Tech.com
VIN: WAUZZZ4E65N014192 License Plate: GO02CAT
Mileage: 215800km-134091mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 19 1E 25 28 34 36 37 38 42
46 47 4F 52 53 55 56 57 61 62 69 72 76 77
VIN: WAUZZZ4E65N014192 Mileage: 215800km-134091miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 1010
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 Q HW: 4E0 907 560
Component: 4.2L V8/5V G 0030
Revision: 00000000 Serial number: AUX3Z0DD356295
Coding: 0011773
Shop #: WSC 00000 000 08192
VCID: 2F6A8B93BE0EEB46F4-807A
4 Faults Found:
16814 - Catalyst System; Bank 2
P0430 - 002 - Efficiency Below Threshold - MIL ON
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
17819 - Secondary Air Injection System; Bank 2
P1411 - 002 - Insufficient Flow
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 S HW: 09E 927 156 A
Component: AG6 09E 4,2L5V RdW 0020
Revision: --H01--- Serial number: 0052057
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 326C82E7AD3CC6AE9B-8066
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008597
Shop #: WSC 00640 000 00000
VCID: 224C72A7FDDC562E6B-8076
1 Fault Found:
00526 - Brake Light Switch (F)
011 - Open Circuit - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 C
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial number: AUX3Z0DD356295
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: 58B8104FEB00CCFE45-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
2 Faults Found:
00191 - Passenger's Door Handle Touch Sensor (G416)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 14
Reset counter: 233
Mileage: 214544 km
Time Indication: 0
Date: 2015.12.10
Time: 20:35:28
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 232
Mileage: 214624 km
Time Indication: 0
Date: 2016.01.14
Time: 19:58:14
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Shop #: WSC 00000 785 00200
VCID: 234277A3E2C65F2660-8076
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 300AH057548066
Coding: 0000002
Shop #: WSC 00000 000 00000
VCID: 3A7CAAC7754C3EEE53-806E
Subsystem 1 - Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
Subsystem 2 - Serial number: 318AD057515140
Subsystem 3 - Serial number: 7419.01.0500000000218B0050˙
Subsystem 4 - Serial number: 8B0050˙
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 178
Mileage: 214553 km
Time Indication: 0
Date: 2015.12.10
Time: 19:48:29
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 A HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 016 0340
Revision: 00000029 Serial number: 00000000059730
Coding: 1069073
VCID: 1B324F43DAB667E6A8-804E
3 Faults Found:
00065 - Rear Left Footwell Heater (Z42)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 29
Reset counter: 183
Mileage: 200260 km
Time Indication: 0
Date: 2015.06.06
Time: 14:06:10
Freeze Frame:
Voltage: 11.30 V
00066 - Rear Right Footwell Heater (Z43)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 232
Mileage: 200261 km
Time Indication: 0
Date: 2015.06.06
Time: 14:14:10
Freeze Frame:
Voltage: 12.80 V
01858 - Air Outlet Sensor; Right Center (G348)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 221
Mileage: 214574 km
Time Indication: 0
Date: 2015.12.12
Time: 22:25:23
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H12 0210
Coding: 0120121
VCID: 316E8DEBA83AFDB6E2-8064
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000036
Shop #: WSC 02313
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0431707
VCID: 63C237A3A2461F2620-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112141
VCID: 65C629BBAC726116CE-8030
Component: Lenkradmodul H05 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 H HW: 4E0 920 950 H
Component: KOMBIINSTR. VDO H53 0200
Revision: D05 Serial number: AUDID3E0000050
Coding: 0000404
Shop #: WSC 00443 067 57207
VCID: 295E658B80EA85762A-807C
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H07 0070
Revision: 07 Serial number: 16003049161CE4
Coding: FDFE7FDC2B3504
Shop #: WSC 00640 210 83262
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 229
Mileage: 215417 km
Time Indication: 0
Date: 2016.01.18
Time: 16:24:55
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD7106789
VCID: 1C304C5FDFB860DEA1-8048
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0412672
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 233
Mileage: 214544 km
Time Indication: 0
Date: 2015.12.10
Time: 20:35:28
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 232
Mileage: 214624 km
Time Indication: 0
Date: 2016.01.14
Time: 19:58:14
Address 28: HVAC, Rear
Cannot be reached
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015520
Shop #: WSC 67148 512 1446452
VCID: 2A5C9A8785EC8E6E23-807E
4 Faults Found:
01583 - Leak in System Detected
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 233
Mileage: 214615 km
Time Indication: 0
Date: 2016.01.14
Time: 17:21:14
01437 - Control Position not Learned
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 178
Mileage: 214553 km
Time Indication: 0
Date: 2015.12.10
Time: 19:48:30
01400 - Suspension Level Control
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 22
Reset counter: 232
Mileage: 214555 km
Time Indication: 0
Date: 2015.12.10
Time: 20:49:39
01772 - Signal from Level Control Pressure Sensor (G291)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 233
Mileage: 214563 km
Time Indication: 0
Date: 2015.12.11
Time: 18:15:27
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H08 0060
Coding: 4063338
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H44 1060
Revision: 00000000 Serial number: 305AK057565443
VCID: 3B72AFC37A7607E648-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000429500044
Coding: 0035972
VCID: 1D36415BC4A269D656-8048
5 Faults Found:
00215 - Control Circuit for Reading Lights Rear Right
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 181
Mileage: 214584 km
Time Indication: 0
Date: 2015.12.29
Time: 00:21:00
00214 - Control Circuit for Reading Lights Rear Left
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 181
Mileage: 214584 km
Time Indication: 0
Date: 2015.12.29
Time: 00:21:00
02140 - Control Circuit for Left Front Makeup Mirror Light
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 181
Mileage: 214584 km
Time Indication: 0
Date: 2015.12.29
Time: 00:42:00
02282 - Sunroof Drive; Obstruction Detection
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 222
Mileage: 214592 km
Time Indication: 0
Date: 2016.01.06
Time: 18:00:00
02141 - Control Circuit for Front Right Makeup Mirror Light
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 184
Mileage: 214688 km
Time Indication: 0
Date: 2016.01.14
Time: 22:33:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Component: Türsteuer.FS BRM002 0060
Coding: 0000512
VCID: 204878AFF3D0443E7D-8074
1 Fault Found:
02110 - Window Regulator Switch
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 196
Mileage: 213968 km
Time Indication: 0
Date: 2015.11.12
Time: 23:41:20
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040412200010
Coding: 0004345
VCID: 275A63B396FEB3063C-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0050
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
5 Faults Found:
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 67
Reset counter: 192
Mileage: 214555 km
Time Indication: 0
Date: 2015.12.10
Time: 20:49:35
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 232
Mileage: 214577 km
Time Indication: 0
Date: 2015.12.12
Time: 23:02:38
00892 - Switch for Trunk Closing Cylinder (F248)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 36
Reset counter: 229
Mileage: 214581 km
Time Indication: 0
Date: 2015.12.18
Time: 20:14:08
01699 - Motor for Central Locking; Hatch/Trunk (V53)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 229
Mileage: 215417 km
Time Indication: 0
Date: 2016.01.18
Time: 14:33:15
01565 - Luggage Compartment Light (W3)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 3
Reset counter: 229
Mileage: 215417 km
Time Indication: 0
Date: 2016.01.18
Time: 16:12:27
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0460
Revision: PROD_01 Serial number: 00000000009844
Coding: 0000017
1 Fault Found:
02095 - Component Protection Active
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 233
Time Indication: 0
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000054576
Coding: 0010101
VCID: 1E344657C9A472CE4F-804A
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: Türsteuer.BF BRM002 0060
Coding: 0000512
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000531
Shop #: WSC 00443 210 85062
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Revision: 00000001 Serial number:
Coding: 0000001
VCID: 62CC32A7BD5C162E2B-8036
1 Fault Found:
01310 - Level Control System Control Module (J197)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 214552 km
Time Indication: 0
Date: 2015.12.10
Time: 20:32:27
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396AO057503292
Coding: 0000001
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 G HW: 4E0 919 146 C
Component: TV analog TUNER H14 0300
Revision: 00000013 Serial number: 00000000001651
Coding: 0000003
VCID: 254669BBECF2A1160E-8070
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: ENERGIEMANAGER H12 0390
Revision: 00000000 Serial number: 00000000000611
Shop #: WSC 00001 210 58515
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 1501170013
Coding: 344530393135313035412056413031353031313730303133
Shop #: WSC 00000 128 00289
4 Faults Found:
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 214585 km
Time Indication: 0
Date: 2016.01.06
Time: 17:20:29
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 214585 km
Time Indication: 0
Date: 2016.01.06
Time: 17:20:40
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 214585 km
Time Indication: 0
Date: 2016.01.06
Time: 17:20:50
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 214585 km
Time Indication: 0
Date: 2016.01.06
Time: 17:21:00
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM002 0060
Coding: 0028462
Address 69: Trailer Labels: 4E0-910-383.lbl
Part No SW: 4E0 910 383 C HW: 4E0 907 383 C
Component: ANHAENGERELEKTR 004 0060
Coding: 0000001
VCID: 244074BFE7C8581E19-8070
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 15
Reset counter: 232
Mileage: 213852 km
Time Indication: 0
Date: 2015.11.10
Time: 16:39:00
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM002 0060
Coding: 0028462
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08720501302926
Coding: 0001008
VCID: 214E7DABF8DA4D3672-8074
1 Fault Found:
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 17
Reset counter: 188
Mileage: 214553 km
Time Indication: 0
Date: 2015.12.10
Time: 20:32:23
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 F HW: 4E0 862 333 C
Component: TELEFONMODUL EU 0770
Revision: 00000006 Serial number: T2AUDX0505HJ01
Coding: 0000004
End-------------------------(Elapsed Time: 04:10)--------------------------
Old 20th January 2016, 01:59 PM
Lee S Lee S is offline
There seems to be a lot of failures in there. Have you cleared down all error codes (Clear DTCs) and then rerun the auto-scan to get an accurate picture of the state of the car?
Lee
2017 Nissan Leaf Tekna
Old 20th January 2016, 03:18 PM
A number of the codes look like the normal transient power blips. The rear footwell heaters are a common failure in D3.
As Lee says.. clear them down and see what comes back.
