Old 1st June 2020, 12:24 AM
Audifan Audifan is offline
Default Cam tensioner parts?
I finally bought both OEM cam tensioners (it's STUPID how they charge a ton on money for them!) and need to know what other parts (I know I need to buy new valve cover gaskets) I need to buy to do this job? I'll be buying new cam chains next.
Old 1st June 2020, 12:34 AM
Stromaluski's Avatar
Don't forget valve cover gaskets.
Not sure what sort of maintenance your car has had, but now would also be a great time to do the timing belt, water pump, thermostat, fan bearing, serpentine belt, serpentine belt roller/tensioner, spark plugs, etc.
-Andrew
1967 Bus
1980 Rabbit Pickup
1992 Corrado
2001 S8
2010 Jetta TDI Cup Edition
Old 1st June 2020, 06:36 AM
You will also need the gaskets under the tensioners, good quality silicone sealant, and assuming you leave the exhaust cam in place one cam blanking cap and I think three cam oil seals.
Gasket: 077 198 217 (2x)
Blanking cap: 078 103 113 E (1x)
Cam oil seal: 026 103 085D
Audi prices for the cam seals are stupid so I usually buy Elring.
Old 1st June 2020, 10:15 PM
Yes I know I need new valve cover gaskets. Also I do plan on buy new parts to do the timing belt job.
Thanks for said parts with part numbers
